Can you diagnose my problem?
C-Tidda
Alright, here we go I hope this description helps you guys out...... I stopped at a red light today like I usually do, then the light turned green so I stepped on tha gas and noticed a weird type of vibration coming from under tha right side of th car. It does this every time I come to a complete stop..... Next problem, when I'm on the E-way I get the same type of vibration coming from the rear-end of the car. It doesn't do it continuously, but once every E-way drive is enough for me.
JerZeyStangz
Northern NJ
My guess is that if your getting some type of vibration under the car, you might have a failing motor mount. This happened to my best friend in his vert, he blew out the motor mounts making his mid pipe bang up against the floor. Vibration near or on the rearend could be a lot of things. I would check the u-joints near the driveshaft for some play, then work my way back. I had a weird vibration in my rear a long time ago, but after I got it built up, never had that problem again. Just my 0.02 Cents.
