Car has a "HICCUP"
the last couple of days when i am cruising at a constant RPM my car will kind of have a hiccup(the car feels like it jerks or has a miss when this happens). this usually only happens every once in a while. well tonight i was leaving my parents house to come home and when i started my car it had a surging idle and died once while i was letting it warm up. on my drive home it would "hiccup" constantly. felt almost as if i was constantly hitting the throttle with my foot(like on off on off on off). I need help on what this might be!! IAC? MAF?
Grim94GT
Sounds like the MAF I had the same problem a while back on another mustang. Try hitting it with some MAF spray cleaner they sell at Autzone or Oreilys
2slo95fiveoh
Lawrence, Kansas
Is the check engine light on? There can be a number of different things that could cause this... I have had: bad gasoline, failing o2 sensors, broken
ignition wire, failing ignition coil... all cause the same symptom.. If there are no codes present, I would think about the basics: (spark plugs, possible
fuel filter, mass air flow, vacuum leaks.. etc.)
Z
it was the maf.. pulled it off today and cleaned it. car runs like a raped ape again! i should probably clean it every now and then since my filter sits down in my fender.. i have had dirty MAF's before and usually my car just runs a little shitty and doesnt have power.. so this was a new symptom for me but none the less fixed!!
Do you have a good engine block ground wire? I didn't for a while and it was making my car act pretty funky. Idk just something to check.
