Car shakes on acceleration, shifter shakes violently around 80
thetruegears
So I've got a 1994 GT 5.0 5 Speed and when accelerating normally you can feel a decent vibration/shake. It happens worse when in 4th gear. And if I get past 80 is shakes like CRAZY. The throwout bearing or pilot bearing has been broken for a while not and I've been driving on it. The shaking didn't seem to become a problem until right after the car started making bad sounds from the throwout/pilot bearing.
Does anyone know what is causing the shaking? Please help, it makes my car feel so shitty
Corndiddly
Collins, WI
Sounds like a drive shaft vibration to me. I would check u joints and see if any driveshaft weights came off. Mine shook bad after 70 mph and it ending being my drift shaft out of balance.
Mustanger
Southern Oregon
You are driving on a bad throwout or pilot bearing....??? Ok first thing is to replace those & maybe the clutch while it is out...inspect everything the others have mentioned...gotta start with the bad parts gone I think THEN you can make an intelligent guess as to were to look next if needed.
