Car sometimes has trouble starting
kissrocksforever
Ontario, Canada
Battery and Starter are fine. I think it's a fuel pressure issue but I'm not sure. It starts normally if I turn the key to ON a couple times before starting it. Lets the fuel pumping prime so that's my reasoning for thinking maybe fuel pressure is low? It drives fine. Doesn't bog or anything.
ivan12
If its a higher mileage car the pump is probably on its way out, you can always check the pressure at the fuel rail by connecting a gauge on the Schrader valve. You can get a replacement Wahlbro pump for a little less than $100
justi88
Cochabamba, Bolivia
ive also have that problem, especially in the mornings it hesitates on turning on, also noticed when i stop to put gas i then try to turn the car and it also hesitates and sometimes backfires and wont pass 1500 rpms for a second and then it runs ok.. what could be the issue with this?
