Car wont turn on.
ZachSav
I just finished a t5 swap in my 95 v6... how can i wire the neutral safety switch to bypass it. i cant turn it on no matter what i try. i need help big time so i can enjoy the new 5 speed.
ram360
you can just unplug the nss and put a fuse in the connector or just splice the 2 wires together. That's what I did on fox body's in the past, prob the same on an SN
Z
ZachSav
are you talking about the red/gray and white/pink wires together? or both sets of connectors?
ram360
if you unplug the harness from the nss you should be able to jamb a fuse into the end of it. that's assuming it's a similar style connector to those on the fox stangs. Like I said I'm not too familar w/ 5spd sn95's but the principal might be the same. good luck
Z
ZachSav
yea but like i said, ther is two connectors under there, with two different color wires. i put the pink/blue and white/pink ones together and nothing, but the is a plug that goes to nothing that is just looped with a single wire, that plug has two sets of pink/blue and white/pink in t, should i loop all of them?
ram360
are there two connectors that plug into the nss? and two wires on each connector?
Z
ZachSav
yes... and both are plugged in and doesnt work, then i unplugged the white/pink, red/blue wire and jumped them together, still nothing
