CCRM woes
Steven
SC
Having issues with CCRM. I have like 3 different ones. Each one with a bad portion. The one on the car, the fan would hardly if ever kick on. Then I just noticed that the AC clutch won't engage now. The other one the fan stayed on constantly. You could cycle the switch a few times and then it'd kick off when you started the car up. No problems with the fuel pump or PCM. However I did crack mine open to find someone took it upon themselves to solder in a new WAC and PCM relay. Going to the JY tomorrow to pick up a few of them to see if it makes any difference. The one I replaced the CCRM on the car with, was an old one I had from my old 95 GT which I believe had problems. Seems to be the case. My question mainly regards where the actual ground for the CCRM is located. I want to make sure it is up to par.
Steven
Steven
SC
after opening it up I don't really see any of the circuit board printing near the rivet holes that could possibly be for it. Hence why I think its through a wire.
Battery neg. comes in on pin 15
That goes to 3 of the 5 relays inside.
the other 2 relays go to the cooling fan relays, and they are gnd'd through the fan
Steven
Steven
SC
Good news, picked up another CCRM and it worked. Problems solved, phew
Steven
Steven
SC
CC'S95GT said:
did you get the ccrm from a j/y or remanned from a parts house?
Junkyard. Found a really clean V6 car that apparently kicked the bucket. Apparently the module in it had been replaced once before. Had a date from 01 on it. 94-00 mustangs use the same one, as well as 95-02 windstars. Pretty straight forward. I can buy a new ford one for 65 dollars shipped but this one was free so no complaints. Put it in yesterday and its been working great since
330CubeGt
Where is the CCRM located on the 94GT's, In the pass side fender.
