CentriVsPdVsTurbo
Blakonblak94
Blakonblak94
Thats on stock suspension? Impressive. What sort of HCI and what psi was that running on? How long did the motor hold up?
modo
Philadelphia, PA
yup
afr 165, b-31, gt40, 14 lbs. week later it went 11.12 @ 126 on radials but i don't have a video of it. motor was fine. i sold the s-trim and put a t-trim on it and the car was a lot stronger. never took it to the track cause i had the 331 sitting and eventually put that in. i sold the 302 parts and the shortblock is on a stand in my garage.
Blakonblak94
Blakonblak94
Sounds like a pretty sweet setup. Those 165's let you have a little more down low?
modo
Philadelphia, PA
car had a blower on it when it was 100% stock so it always had a lot down low. blower was the first mod i did lol.
Blakonblak94
Blakonblak94
That sounds like plenty. What else would I need. An intake elbow, discharge tube? Oil feed and pulleys?
BLOWN 95GT
Alabama
adjustable fuel pressure regulator, oil feed , oil drain, pulleys, belt, fuel pump, injectors, mass air meter, intake elbow, discharge tube, brackets, tune.
Blakonblak94
Blakonblak94
Could I use a draw thru setup or would it have to be blowthru. ADj fpr is taken care of. How hard is it to usually come about a decent headunit?
BLOWN 95GT
Alabama
Doesn't matter both will work.
I really don't know I have seen a few on ebay but don't know how many people on there you could trust.
ProKiller
PA
a centri is more street friendly IMO. you won't even know its there until you get into it. you can find almost full kits on corral for under 2500 all the time.
BLOWN 95GT
Alabama
A turbo is more efficient, and puts less of a load on your motor. Even at idle your engine will have a load on it where a turbo freespins, and with the right kit for your combo will have almost no lag at all.
Blakonblak94
Blakonblak94
I suppose we'll see what things come to this coming spring. I should have a decent little chunk of cash saved up.
