check this out
Cali95gt
Has anyone had any experience with boostbrothers turbo kits for our cars? I ask because they are only $1600 brand new. sound like a deal compared to the 4 plus grand for other companies.
LAFENATU
When it comes to aftermarket products trust me when I say:
You get what you pay for.
The best turbo kit out there for the money is B&G Turbo Kits. They are right around $3000
C
Cali95gt
true, but 1600 is a really cheap price. just the materials should equal that much. how much power does a turboed stock 5.0 put out?
castine917
wyoming, mi
he posted on corral pm for info in 2008 and i just posted he should post info on there.
the $1600 price appears to just be to get the company selling to get a name out but this the first i have heard of them.
d_punch
thats the worse business plan anyone could use. i wonder what the plan will be when everyone is still lookng for $1600 kits?
LAFENATU
I know a guy with a stock foxbody with a turbo technology kit and he makes just over 450hp and 510tq.
I think the turbo is a T66 with a .82 housing.
C
Cali95gt
Think at the end of next month if they still have it i will pick it up just for the hell of it
d_punch
i don't see this as a very good design system.
"Tuning package available - including injectors, MAF and fuel pumps! Installation of this kit is fairly straight forward. You will need to relocate or delete the ABS module, add spacers to the sway bar, remove the smog pump and modify the radiator support (for air filter clearance"
first, there is no support to your fuel system, you will have to add that to your cost. relocating your abs is not straight foward. adding spacers to your sway bar, is a sign of a very good design ;) modify your rad support, thats the killer right there for me. honestly i would save your 1600 for something better.
LAFENATU
Spend the extra $1000 and get a PROVEN kit.
B&G STAGE 1 1994-1995
Starting at: $2,750.00
!!!!!!!!!!TAX TIME SALE!!!!!!!!!!FREE SHIPPING !!!!!!!!!!!!!! MUST BE ORDERED ON LINE TO GET THESE PRICES!!!!!!!!!!!!!!!!
B&G'S gen 4 kit It can not get any better!!
It now comes standard with a Master power T-70
Requires slight triming of the hole infront of the passside strut tower. (mostly just opening up the hole slightly) Is to be used with energey suspension mounts. Keeps all accessories (except smog) We have put great effort into making a great fitting kit that only needs to be built once, it is guarnteed to fit your mustang without you having to rebuild it just to get it to work. As long as your mustangs frame rails are where they supposed to be, I guarntee this kit to fit. No more cutting up your whole inner fenderwell just to get a ill fitting kit to work. WILL NOT WORK WITH CONVERTABLE STYLE MOUNTS!!!! If you want to run convertable style mounts you will have to cut on the car, or run spacers!!!!!
Will Fit up to a t-78. 94-95 5.0 KIT Hotside Comes with:
1. Drivers side, 16 Guage mild steel header with 1/2 flanges. 38 MM wg flange installed. Machined V-band flange (not that pressed junk others offer).
2. Passengerside, 16 Guage mild steel header with 1/2 flanges. Machined V-band flange (not that pressed junk others offer).
3. 16 guage mild steel crossover, with stainless flex joint, machined vband flanges.
4. 14 guage mild steel mandrel bent 3.5 downpipe.
5. Kit comes with your choice of turbo see selections below or call for pricing.
6. 38 MM Silver B&G or Turbo Concepts Wastegate standard. Any bar up to 1 Bar. (higher available at higher cost.)
7. 1- Turbo outlet stainless v-band clamp
Cold side comes with:
1. VS Racing INTERCOOLER, 600,750, 825 Precision units available upon request.
2. 2.5" turbo to I/C cold side pipe, with BOV flange installed.
3. 3" Intercooler to throttle body cold side pipe.
4. 50MM B&G/TC B.O.V
COLD SIDE SILICONE KIT INCLUDES:
1. 2- 3" hts couplers
2. 2- 2.5 to 2.5 coupler
3. 4- 3" stainless band clamps
4. 4- 2.5" stainless band clamps
5.2- 2.5" stainless v-band clamps
OIL LINE KIT INCLUDES
Full oil line kit, all -an fittings Braided lines.
Comes with:
1. Turbo drain flange
2. Oil Pan Bung
3. -10 Oil drain line (Braided stainless steel with -an fittings on both ends.)
4. -4 Oil pressure line (Braided stainless steel with -an fittings on both ends.)
5. Turbo oil pressure inlet fitting.
6. Block fitting.
C
Cali95gt
true again. i checked out that one. its just that i will be getting my financial aide check pretty soon for school and its about 1200. i just wish some had it already so i could know what were the bad parts. but if i do get it i could just custom fab some things
