Cold air intake ?
russ8825
NY/FL
Hi everyone, first post lol
I was wondering was it worth replacing the stock air system with a CAI ? If not what other mods are worth getting for around the $100 range. I have a 95 GT thats pretty much bone stock, I have a transgo kit i have to get installed but thats it.
-Thanks
CAI are mostly for cosmetic gain and you can find $50 on eBay that work pretty well, i wouldn't pay full price for one.
98mstanggt
Louisiana
Yeah just buy a cheap cai off ebay or something all cai's work the same just depend on rather you like the way it looks(Chrome, black, inside fender, etc)
white95
Apex Junky
Admin
Prairieville, LA
You will only be as good as your weekest link... A cai will provide a slim gain in power but the stock throttle body and mass air meter will restrict the airflow. I vote for a set of underdrive pullies and advancing the timing to start!!
Venom351R
Maine
advancing the timing is free and will net you more HP then a CIA set up will but you also have to run 93/91 octane once you bump the timing up
white95
Apex Junky
Admin
Prairieville, LA
^ is correct. If not, it'll sound like kim jong I'll firing little nuclear missiles into your pistons. I usually pay about 35-40 bucks a tank to go rolling in my 5.0. Worth every penny!
LAFENATU
I bought a UPR piece. Nice and worked well BUT the only reason I bought it was because my stock setup was bad.
If not for that I would simply run the stock setup with a K&N Panel Filter.
.02
^+10000000000
Unless somethings wrong with your stock setup, keep it and throw a K&N Filter in it and call it quits.
2slo95fiveoh
Lawrence, Kansas
Or, I believe there was a thread about making your old cold air kit from PVC pipe from a home improvement store..
here ya go: http://sn95forums.com/index.php/topic,19849.0.html
Yours would look a little different because of the fox intake, but same basic principle..
Then take the money you save by doing that, put it in a jar, and save up for GEARS.. you'll be glad you did.
russ8825
russ8825
NY/FL
Cool thanks guys. Question though, My car has the stock 3.27's in it, how bad would i see my gas mileage go down if I threw 3.73s in ?
on my last trip my car's mpg was almost 24 mpg/tank, i have 3.73's, 5 speed and longtubes.
IMO not too bad
Venomous96Cobra
Central Florida
I have the BBK cai that came with my car when I bought it I see no difference between it and the cheap ebay cai I had on my foxbody! both were fenderwell kits and the only visible difference is that the ebay one which is probably about $100 cheaper didnt have a BBK badge on it...
white95
Apex Junky
Admin
Prairieville, LA
I suppose the factory air tract would be less prone to "heat soak" than aftermarket steel/aluminum tubes. The JLT cai is supposedly one of the best out there for now..
