Comp Stg 2's
PI96GT
Is anyone running comp stg 2's on here with an NPI bottom end? im just curious if there is any worry of sucking a valve because the npi pistons are much shallower than pi's
I ran them but i had aftermarket valves that have smaller margins then stock.
And its not the piston, the PTV occurs on the edge of the piston so you can have a 35cc dished piston and still get ptv.
The issue is the stock PI Valves have a thick margin so like Hitech suggests you can have them ground down or get valve reliefs cut in the piston.
P
PI96GT
aight cool thanks, ill have the valves ground down since the heads are being ported and assembled at bo-port in fremont, they do great work so i cant trust them with it
duff daddy
I have 270's on my car before getting rid of them a week ago, and sold them to a member on here who i think is also pi swapped.....
Willis_98GT
DFW Texas
their the exact cam that i have. from what ive learned you can use factory timing and not worry about anything slapping.. enjoy 10:1 and cams
duff daddy
Degreeded cams rule the world and should ALWAYS BE DONE !!! No reason to install cams and give away free hp
Willis_98GT
DFW Texas
Duff Daddy said:
they will be degreed on the rebuild duffy, i just dont have the time or paitence. and plus if im going to tear it apart later on then what the hell is the point.
