coolant leak
sbr420a
what is the easiest way to track down a coolant leak???? at first i thought it was cold leak but now iam not to sure. i can see a coolant drip from the harmonic balancer, and i see a small little puddle right beside the dizzy. i know it isnt the intake manifold or head gaskets. it started after i replace the water pump. so i tightened the bolts again but to no prevail. it isnt the hoses or the thermostat housing my guess is the timing cover but how would i know for sure. right now it is on jack stands. i cleand the areas in hope of me catching it in one particular spot. any help would be appreciated
sbr420a
never mind guys i found it. it is leaking at the timing cover right underneath the factory oilpressure switch location. is it a bitch to do the timing cover?
franky694
very time consuming even if you know what your doing. Its gotta be done tho, you cant roll around like that for very long..
