coolant temps
2broke2gofast
Got a set of AFR heads on my 95. Put a manual gauge in it, and rolling down the road it'll run around 200*, but will reach 220* before the cooling fan comes on. the car will then get back down around 200*. Is this correct, don't want to warp heads. Thanks
ryclef331
yes thats correct for your factory setup. The fans aren't programmed in the ECU to come on until then. You can run a 180 degree thermostat and either have your car tuned to turn the fans on at 180 OR run a manual fan swtich (see the sticky above). You can also run a thermally controled switch to activate the fan as well. Its all in the above sticky.
Suspect
ATL
i just double checked in my haynes and thats right. i think i replied in the other thread.
peasant99
