Cooling fan stuck on
borlakid96
STL
I have a 96 gt with the cooling fan stuck on and the only to turn it off is pull the fuse. It stays on with the key off the whole time it's running. It defiantly runs colder I am assuming its a short to power. Stuck closed relay or somethingif anyone knows anything about this teach me stuff I don't know much about this circuit. Ill print off wire diagrams and try to trace something. Please and thanks
97FloridaGT
My guess is going to be a stuck relay....not uncommon to happen, especially if it's an original. Buy a new one and start from there. The cheaper the better, right?
borlakid96
borlakid96
STL
Well I only seen a fuse for the fan I don't see a relay. I seen people talk a bout ccmc or something like that. I have no idea where it's at what it looks like it stands for constant control module circuit under the over flow. Seen nothing
borlakid96
borlakid96
STL
Is it common for it to just be a relay? Thanks for helping guys appreciate it. This is the type of things that bug me haha
CC'S95GT
Hampton ,Ga.
CCRM= constant control relay module
it houses the relays for the hi and low speed fans, a/c compressor, and fuel pump.
borlakid96
borlakid96
STL
Would the fan relay in the module effect my fuel pump or maybe the compressor? I think my mpg might have went down. Where can I get one? Online or junkyard probably.
CC'S95GT
Hampton ,Ga.
NO. there are 4 seperate relays inside the CCRM.
If your MPg's went down then there is a diffeent prob.
I have heard of some parts houses carrying the CCRM but I don't know which ones.
borlakid96
borlakid96
STL
Ill probably end up going to a junk yard and getting on or somewhere online. There 150+ for remanufactured another 100 or so new give or take. Thanks for helping me out
CC'S95GT
Hampton ,Ga.
there was a thread recently about a guy that got a 95 taurus CCRM. It worked great plus as an added feature, when you shut the car off the fan would remain on till the rad. cooled off.
F48F-12B577-AA
