Cranks but not start with "Vent" on Question
YUNG VEEZU
Ft. Carson, CO
Hey guys just a quick question, I had my Vent left on earlier this morning. Came back to the car an hour later and she would not start at all. She would crank but thats about it. I tried starting her a few times every few minutes until I realized I left the Vent switch on. So I decided to turn the switch to off, and she started with no problem. Why did my car do that? Shes a 97 Cobra all stock besides mufflers with 113xxx original miles on it
KillNThrill24
Cleveland Ohio
Sounds like maybe a vacuum leak somewhere in your hvac if I had to guess. Pop the hood and make sure all your vacuum lines are attached and not rotted out
Sent from my SCH-I605 using Tapatalk 2
g36 monkey
Orlando, Fl
Do a smoke test. Take a cigar, pull a vacuum line, exhale smoke into the vac line, then look for smoke coming out anywhere. It does sounds like an HVAC leak of sorts. When you try it, make sure to have that in "vent" mode.
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
Never tried that before, but sounds like a good test. I'll try it in a little bit
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
Can't do the test till one of my buddies comes over to take a look later this week, and hes bringing some cigars
g36 monkey
Orlando, Fl
Haha! Sounds good dude! Just did the check last night on my buddys 96GT, sure enough big leak in his pcv
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
Well my buddy "accidentally" smoked his last cigar before I got to his house. He's going to buy new ones on the 16th after payday. Damn!
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
you can also pull the controls out from the dash and inspect the vacuum lines in the dash, as well.
I'm not too familiar with the dash, you wouldn't by chance have any pics would you? I only see wires and don't want to touch anything causing any more problems
MustangChris
Aurora, CO
well the shroud around the vents just pops out (take your time, it can easily crack) behind that shroud are 4 screws holding the controls in. Unscrew those and inspect the vacuum lines behind them :)
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
Oh I got you. I took those apart before (LED cluster) but I always had trouble taking the radio out
KillNThrill24
Cleveland Ohio
That's because the Ford security radio thing is fawking annoying lol. Yeah check those lines out man make sure nothing is unplugged. Also turn the key into the on position (turning the car on will make it harder to hear) and cycle through the controls at different speeds and settings and see if you notice a difference
svt slobra
ohio like everyone else
my 01 cobra did the same exact thing guys. it ended up being a bad cell in the battery. the first thing to have power taken from it was the coils. so if an accessory was on when trying to start, it would have weak spark......hope this helps ya out man
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
Just put in a new battery last month. But I haven't changed my spark plugs and wires since last year
YUNG VEEZU
YUNG VEEZU
Ft. Carson, CO
Well, haven't done a smoke test HOWEVER she overheated. I drove her to the store and back home, the gauge went all the way up to High. I looked under the hood, the coolant leaked out of the overflow tank cap. So I talked to a few buddies and they told me to "burp" the system.
So this morning I let her run without the cap on to get the air out, and filled her with coolant. I took her to the shop and she ran fine, the techs said they smelled a hint of exhaust in the coolant tank, and said I may have early signs of a blown head gasket.
I just put in a new radiator, cap, thermostat, hoses a few weeks ago. The fan runs too. I had a 88 Fox that had a blown headgasket, and I don't have any smoke coming out of the rear and no milky oil. BUT sometimes she has trouble starting. I don't abuse her either. I shift around or under 3000 rpm range. I have never changed a head gasket and know it takes a lot of work. Damn!
