custom head and cam swap
cody0170
so i has googling and was curious.... i have a npi motor now and am wanting to do a pi h/c/i swap and was thinking well i can go all out and do a little at a time like get some ported heads and a set of custom cams and then save for a kenne bell and during that i can try and find a low millage pi motor then swap my heads and cams to it and since everything will be pi the compression will be low again.
whats a set of custom cams and ported heads rwhp with a npi block. and which ones should i go with.
Jrgunn5150
A set of Foxlake Stage II heads and VT stage II cams will shove you right past 300 rwhp on a NPI block. Good idea BTW, exactly what I did.
A tip though, don't buy NA cams unless you get them used cheap, if you are really going to buy a blower, go straight to blower cams now.
AaRoN
King Post Whore
Got a link for those?
Jrgunn5150
They do labor too, but they are awesome quality. I had mine for quite awhile and never a problem.
Jrgunn5150
I initially did a PI head swap an VT Stage I's, that was like 288. Then I went to the head's and stage II's for the win, 312 rwhp. Then I stopped goofing around, built the stroker, strapped on a Novi 2200, and stage II blower cams to hit 463. MPH custom cams took it to nearly 500
Jrgunn5150
voidfinger said:
yea thats pretty steap compaired to other companies.
Compared to who? Patriot? I wouldn't use their head's to hold down paper.. For quality it only goes up in price, those were the cheapest heads I would even use.
AaRoN
King Post Whore
Power costs money....I will admit that aftermarket heads (good ones) are pricey, but like J.R. said: If you want a bada** modular then you gotta spend the $$$
voidfinger
the average heads cost in the area of 1300/1500 dollars. I wouldn't spend over that, if i had to i would go buy a 5.0 an put some race heads on it for that :) , just not worth that amount of money IMHO. But to each their own right. My boat floats with the cheap modulars :santa_grin:
Jrgunn5150
From where?
voidfinger
Well for one, there is the Johnny Lightning head which is like 1500 i think, it is the same head that is on their 9 second truck. Extreamly good F.I. Head.
Then, even though they're on the rocks, but vt had some good heads that was under 1500. I was looking at those about 8 or so months ago. And there are others. I just know that fox lake has some awsome mod stuff. Just a bit pricey, but i guess you get what you pay for right? i've never heard anything bad about the foxlakes.
