D1SC 2V hit the dyno
nightfire
TX
FINALLY strapped her to the dyno. The blower is pullied for 18lbs but we were getting MASSIVE belt slip on every single pull so it only saw a max of 10lbs.
However, Im pleased with the numbers for only seeing 10lbs. The tune is a bit on the conservative side because its just a street tune. Once I get the slippage fixed, its race gas and full kill on the race tune.
Completely stock top end (heads/cams/POS plastic intake/65mm TB)
421rwhp/415rwtq @ 10psi
Sorry for the sound quality but it was LOOUUD and my Galaxy doesn't seem to handle high volumes very well. He gets on it @ 0:14
https://www.youtube.com/watch?v=IgNBLNk94RQ&feature=youtu.be
Just some idle porn. Straight-cut gears FTW
https://www.youtube.com/watch?v=VcfASb3KzPw&feature=youtu.be
97stanger
What pulley/tensioner setup are you running? Good #'s, and you'll see a HUGE difference with 18psi and race fuel if you have the fuel/spark to support it. Best of luck brother
amy98gt
Summerville SC
I have a similar setup with a 8 rib. The builder told me he has had slip problems with all prochargers on the 2v without 8 rib. Good luck on the car ill be looking in on for updates.
auto_x5.0
Call Procharger and ask about an 8 rib upgrade kit. It will make all pulleys 8 rib since it's a shared drive system.
torch318
They're pretty proud of the eight rib kit and get around $1000 for it. BGG performance sells a eight rib kit for around $750. The kit from BGG is just the eight rib pulleys from Ford for a truck motor with some spacers for the blower if you buy the pulleys from ford they're around $350.
D3VST8R96GT
Marble Fall, AZ
For 1000 ID just go cogged no slip
96blak54
Staff member
Lawrenceburg Kentucky
Heck, I just machined a 5.4l 10rib setup for $1000. Although the guy furnished the $200 aluminum for a 9.5" diameter crank pulley, but still 10rib. 10rib ='s no slip ='s no snapping belts
torch318
If I remember correctly the prochager kit has a I.W. crank pulley so thats $440 alone
