Deleted smog pump hose
bturner425
Grafton, OH
My 95 GT has a smog pump delete pulley installed. This hose is hanging down and is open through the rest of the system. Should this hose be plugged off?
GTamas
Austria
Cat still there.
Check if the inlet at the cats and on the back of the heads is plugged. If not, then I would plug the end of the hose. Or if you want to get rid of the hose, plug the heads and the cats.
The valves of the AIR system are vacuum operated. Make sure the vacuum lines don't just remain unplugged, causing a vacuum leak.
