Thomas_W
What is involved in rebuilding the diff in time? I am trying to weigh the cost with the problem that I have 100 different things to do..
Time wise.. Depends..
if you take the pinion and differential somewhere that has an arbor press, 30-40 minutes to replace those bearings. Then another 1-2 hours to replace axle bearings and seals. If you reuse the factory pinion and diff shims in their original positions and you get lucky, you may not have to reshim the diff and adjust the ring gear backlash
so just a few hours
