Disable low oil sensor?
bumblebee
I have an aftermarket oilpan on my car...
So now I dont have any place to put my Low Oil Sensor, how should I do so the light in the dash doesn't comes on?
I know the easy way is to remove the bulb but thats seems not to be the right way...
Suspect
ATL
yea just take the sensor off the wire then zip tie wire somewhere. ez.
mikey94gt
If its anything like my Moroso oil pan, the drivers side corner will interfere with the clutch cable, if you have a 5spd. It will bend the end of the cable bad enough that it will break the cable. i ended up putting a huge nut around the cable, and it still wants to cut the clutch cable. Ill see if I can get pix later, if you like. it looks like you have the same style kick out though.
B
bumblebee
Yes please post pix about the issue...
I have a different bellhousing then original because I'm going to run with a TKO gearbox but maybe it still interfere?
mikey94gt
If the place where your clutch cable goes is farther out from crank centerline, then it may work. I have a feeling the Moroso oil pans were created for the automatic equipped drag strip cars.
Staff online
