discounting fuel lines from rail
foss_94gt
i cant get the bigger line off the fuel rail , i have the set of discounting things, maybe its not working cause its a cheap set. but does anyone know the size of the bigger fuel line on a 94 gt maybe I'm just using the wrong size( i have never had a problem with this before)
thanks
Justin
Paul
Push them in while twisting, and keep working it in. You'll get it. You'd know if you were using the wrong one - it won't fit right.
ram360
they get stuck on there pretty good even once you undo them w/ the tool...I just wiggle them back and forth slightly and they come right off.
F
foss_94gt
topless95 said:
Make sure you push then pull the lines off
what do you mean by push ?
i have tried like 30 times i still cant get it , would a metal set work better the a plastic set
Addermk2
Follow the line over to the rear of the pass side of the engine bay, and pop off the plastic clip where the rubber meets the steel line... end of problem!
