Dissapointing dyno numbers...
94califiveoh
Came out of the dyno and got 294hp/320tq...very very dissapointed. See my sig for mod info. These numbers were achieved with a vac leak. My lower intake is not seated properly and is leaking air from the lower intake into the crank case. I must not have created a full seal between the lower intake and the heads. Do you guys think if this is fixed, my HP and TQ will go up?
94califiveoh
Sorry, here are my mods:
94 GT Vert: Rebuilt 306 w/domed pistons, compression 10.4 with TFS 170cc heads, 1.6 RR's, stage 1 cam, Tmoss ported lower, 1" spacer, cobra upper, 70mm TB, 76mm calibrated MAF w/24lb injectors, CAI, MAC longtubes/BBK xpipe, 3.73's
Rice_slayer
Ya, that seems normal for a HCI 302. Were numbers from a DynoJet or Mustang Dyno? Mustang dynos tend to read like 10-15% lower than dynojets, thus why my car put down only 270rwhp where as CanaryGT with basically the same set up put up 300rwhp on a dynojet.
castine917
wyoming, mi
i only put 271 hp and 302 tq with my camaro 355 through a glide. granted i had a clogged fuel filter but 49 more cubes and carb. stock our stangs don't even hit 200.
94califiveoh
well then, I guess it is what it is. I'll tell you something though, it was a night and day difference when I took it for a test drive. holly guacamole! major improvement.
I should have it back by tues-wed next week. Hopefuly thats the only issue with the motor. thanks guys
LAFENATU
Those numbers are average.
You don't live on a dyno..numbers mean nothing.
Win
Kennesaw, Ga
With the Fast as cast heads that should be about right.
Agreed 1/4 mile time is where it's at.
330CubeGt
I would be upset to but i would fix your issue and go back and see what it does then make a trip to the track and see what it does...
BlkoutGT
MO
Ya man, before you get down on yourself, fix your leak then get back to the dyno. Good luck.
SN-95.0Beast
94califiveoh said:
well, from looking at your numbers, im pissed. Are your numbers flywheel hp?
those were Numbers Projected through Quarterhorse, on the dyno i Put down 319RWHP and 354TQ, so not that far off from your numbers
Pure84GTT
dont race the dyno, a custom camshaft and a different intake would net you some more ponies
KAOSS
Those numbers are good. Don't be pissed. My 347 stroker made 330 at the wheels NA and was running 7.50 in the 1/8 on a 100 shot. It all comes down to who is faster. Guage your power on the track. There's too many Dyno Queens!!!
SVTurbo 98
Santa Rosa Beach, FL
I agree with this.
What did you expect to make? Your dyno numbers are pretty much on par with what people are making with that combo... Just for comparison sake, I once made 290/295 with a 306 afr165, ots crane cam, tmoss ported gt40 combo on a dynojet.
It's sounds like you're having fun with it though and that's all that really matters.
