Driveabililty Issue
gt96stang
Seems As if my car wants to stall out on me while it's slowing down...
As while I am just coming to a stop, and the car is still in gear it seems to be having a hard time coming back down...
And once I hit the clutch, the car's rpms drop and occasionally they drop too far and it stalls out
Has had the IAC replaced a good while ago..
Just got a new MAF sensor for it as well...
PI intake/bbk throttle body/plenum
gt96stang
gt96stang
bump... nobody has any ideas... I'm stuck right now..
justinschmidt1
Did you try raising the idle?
Use the screw on the TB...loosen it up a turn or so and raise the idle a bit.
gt96stang
gt96stang
Not yet... But the car doesn't want to die while at an idle... After it warms up some the idle bounces but never enough to where it stalls... It just seems once I hit the clutch the rpms drop too fast and gets too low..
Oh, and it also seems to be running a little rich, just from the smell... Even though I do have an o/r x and LM1's, the smell is worse than it has been before..
The car also has a small puff of smoke on some start ups... Not sure what color it is, but it smells...
vacuum leak? or maybe something going haywire with your vacuum on your brakes. ive heard if we (sn95 drivers) slam on the brakes too hard it will stall out the car, because the brakes are run off vacuum for assistance (or something like that... perhaps someone else can clearify what im terribly regurgitating from another mustang owner.)
gt96stang
gt96stang
Yeah, I'm going to have to check it this weekend unfortunately... Probably run a can of seafoam through the thing...
But first, I'm working on getting my speedometer working. I hate my toys. :BangHead: :BangHead:
gt96stang
gt96stang
MustangChris said:
whats wrong with your speedo?
Speedo/trip/odometer do not work... Trying the speedo gear in the trans on thursday once the ford dealership gets it in and gives me a call...
gt96stang
gt96stang
MustangChris said:
o i c. a good place to look for a speedo gera is steeda as well.
Yeah, Steeda only wanted $10 for the piece..... and $12 for shipping... So I went elsewhere.
