Driver side trim broken?
Cochise
So I noticed this today… how do I fix it? Or do I just take it to a body shop?
RAU03MACH
NEW MEXICO
Looks like a sail panel after rear window
Can you get a better shot
Not so close so we can even make what part it is
I am pretty sure there is supposed to be a screw holding it in place. You would need to remove the rubber trim and then the plate that holds it in place and it should be behind it IIRC
C
Cochise
I’m not at home but I’ll get a better pic when I get home. It’s this pice though. But I’m the driver side.
RAU03MACH
NEW MEXICO
like ttocs he said should be some bolts to the inside holing down
unless its broken at the mold where the clip mount to
C
Cochise
I think that might be it. I didn’t see a bolt or clip. Will need to do some research on how that piece installa
RAU03MACH
NEW MEXICO
if it is the top rail that broken and the mounting clip dose not stay together , junk yard should have it ,or you can bond it with epoxy
to make it stay on the clip
senior001
