Driver side window stop working
04BEAST
I have an 04 Mustang GT and my driver side window stop working when I hit the down button on hear a click sound coming from under dash. I ran a wire from a cordless tool straight to the switch and it worked but when I connect it back to switch it doesn’t.
you hear noise under the dash, or inside the door? Sounds like a bad switch but the noise under the dash is confusing
follow the noise and see what it is. There should not be any noises from under the dash. Ford uses a 5-wire reversing polarity system that doesn't require relays.
evilcw311
Most Evil Member!
Louisville, KY
Does the car have an aftermarket alarm??? If so it could have one of those stupid window control modules. That would be under the dash possibly.
But I seriously doubt it. Most people weren’t that dumb.
04BEAST
No doesn’t have alarm at all but the stock one
then there should not be any noise coming out from the dash, related to the windows. Follow the noise and see where it comes from to start.
squirlye
tucson az
I have the same issue,Passenger side works fine. I'm going to see if I can switch the driver side to the passenger to see if it's the switch itself.
I also have a 02 F-150 and the driver side window works sometimes. And same sound comes from under the dash. I've replaced the switch and the relay. But it still does it at random times.
if you can control the window from one side and not the other it could be the switch or a connection to it.
alleghenyamerican
