Is the driveshaft on a '94 5.0 auto the same as a '96 4.6 GT manual? I'm struggling to remove the driveshaft to do my rear end swap, bent a spanner, broke a socket and started to slightly damage the 12 point bolt.
put some heat on the pinion flange but be careful you don't damage the seal. the bolts are probably installed with lock tight. I don't believe the DS is the same but don't hold me to it.
