Dyno Comparison Text: DBX VS PMAS MAF
Venom351R
Maine
I have the opportunity to test out 2 meters in the past few months. The first dyno test was done w/ the DBX 97MM Mass air meter back on May 2ed. This Saturday Aug 8th I'll be going back for a re tune on the dyno but with a PMAS 95MM Velocity mass air meter. Same dyno, no other new mods at all.
Shortly after the May dyno tune ( Put down 333RWHP ) the DBX meter went bad on me. Took 6 weeks of chasing problems to finally figure out that it was the meter.
The PMAS 95MM Velocity meter came from Brown Santa today. I hooked it up and took the car out for a spin and the seat of the pants meter went off the chart!!! I cant belive how hard it pulled, I could not keep the rear tires planted w/ the Nitto DR's. I dont think the Cobra has ever pulled this hard before.
Conclusion: I think the DBX meter was going bad for quite awhile, even for the dyno tune so I dont think the 333 RWHP truly represents what the car has w/ the mods b/c it pulled like a raped ape tonight. It will be interesting to see the outcome this Saturday but I'll be highly surprised if it does not pull more this time around.
VS:
LAFENATU
The velocity meter is great stuff.
Where did you get it from?? Dave @ JD's?
BlkoutGT
MO
Any new word yet on the DBX? I know you sent it back, did they tell you anything
Venom351R
Venom351R
Maine
It was $299 through atomic performance, free shipping.
No word yet from DBX. I was going to call them today but have decided to wait until after the dyno results so I will either have proof that A. The meter was going bad even before then or B. That PMAS just makes a better meter.
This may not be a "fair" test if the meter was going bad before the tune but we'll see.
Venom351R
Venom351R
Maine
Addermk2 said:
why not run a 90mm LMaf for $85?
Because I dont want to. It had a 90MM LMAF on it before and it idled like crap.
Notice the price difference...notice that Im much more happy w/ the PMAS Meter.....
Maybe you had a bad MAF, tons of people including myself run LMAF's and their cars idle just fine. I got mine new in box for $20 to my door and it's capable of supporting pretty big power, not to mention it's easy to tune and extremely reliable. Just because you bought a more expensive MAF doesn't mean it's a better part, 90mm LMAF ftw!
LAFENATU
The LMAF is limited with power. No way around it.
The velocity meter flows more, supports a hell of a lot more power and can support up to 160lb injectors.
wtf is limited with power? and everything else you said is pretty much irrelevant as a LMAF would work just fine for Venom's setup.
LAFENATU
The LMAF is limited on the amount of power it will support.
It will peg after about 450-475HP
Addermk2
i know for a fact that it takes ALOT more then 450-475hp to peg a LMAF. Im running my stock sensor in a C&L housing and STILL have yet to peg it.
want proof? gimmie a few days to wait for my netbook to come in and i'll get you some data graphs showing the kind of air my car flows at high RPM
modo
Philadelphia, PA
a lmaf will peg anywhere from 375-475. blow through setups lose 20% headroom... its a fact. sure you can add a piggyback device like a mafia to get more but that is a bandaid
speed density > maf :p
Paul
I don't know enough about the LMAF to have an opinion on this, but does anyone have the transfer tables to back up the 475 hp "pegged meter" claim?
modo
Philadelphia, PA
i don't have any maf stuff on my computer anymore since i ditched mass air all together a long time ago. a quick search on the corral or hardcore5.0 will show the same as i have stated or a quick email to bob kurgan / don lasota will provide the same.
