Dyno numbers 331 Trickflow / procharger
2002BLGT
Bedford VA
331 DSS stroker Trickflow top end kit stage 2 cam , D1SC procharger 11psi , Detuned to stay under 500 rwhp so it doesnt split the block , tuned with Moates Quarterhorse
475 RWHP 483 RWTQ
ivan12
Nice numbers, I'm hoping to get close to the 400-450 range, with almost same setup except the 331. What fuel upgrades have you done other than MAF and injectors of course?
2002BLGT
Bedford VA
Yes I tuned it
Has aeromotive fuel system which is good , but only 42lbs injectors and I think they are just about at their limit , MAF is Delta Force Bazooka meter which is good as well , personally I would like to see this with a newer slot style meter and 60lbs injectors , I have set the rev limiter about 6200 cause its going a little lean at very top end of 4th , stock blocks dont like RPM anyway , this thing would probably do 550-600 rwhp with more timing and aftermarket block and more boost and more injector
mikey94gt
Nicely done man. makes me wish my combo had a bigger blower, im runnin an S trim at 495hp at the tires, max blower speed. of course, 42# injectors go a little farther when your a mile above sea level.
94GTstanger
Mt. Pleasant,,TN
That is sweet but I want 550 all motor once I finish my engine build...of course I don't even start my build till feb...but im building a 427 stroker. Im buying block and roting assembly with stud girdle and possibly AFR heads...but block and internals for sure.
