E-Brake Adjustment?
All right my cousins got a 94 cobra and we were looking at his e-brake today and its not working lol, anyways i took out that storage in the center consel to get to the e-brake and the cable is connected but extremely loose it has no tension on the lever wat so ever, everything is connected just realy loose, any way of adjusting this any links that guide u to do, thanks
I don't know of a way to adjust it. but check the first cable connected to the handle. As it goes through the floor it fray and brake over time.
You might want to take the rear wheels and rotors off to inspect the e-brake equipment back there for problems
x182dan
theres 3 actual cables I'm willing to bet one is broken. On mine it was the short one that connected to the handle
C
yea it might bet the cable to the handle, we had the car up on the lift cause he was fixing his exhaust clearence issue and i started looking at the cables, and the to rear cables look in pretty good shape the fork where all the cables meet was good but loose i pulled on the front cable and just didnt feel right, would i have to take the consel completely off to replace that cable?
x182dan
I had to take the whole console out dunno if you can do it any other way.
you don't have to remove the console to r&r the cable.
get the rear end off the ground, place jack stands on frame and let tires hang off the ground.
You should be able to get to the cable over the DS from there.
x182dan
You still need to go inside the interior of the car to attach the cable to the handle
DFG_magic
Kennesaw, GA
There is an open recall on the park brake assembly on 94-95's. I'm going to get mine resolved next week. Look into it before you spend money.
correct. you can get to it after you remove the console box.
the recall was about the handle attachment. I think it expired. but it can't hurt to ck anyway.
