DESERTCOX05 said:ck your fluid
the BRAKE LIGHT is duel purpose. 1- it tells you when the e-brake is on, 2- when the fluid in the master cylinder is low.
As an added note; if your brake fluid is low and it's not from leaks then a brake pad inspection is in order
