Edelbrock Victor EFI on 94-95 ?
amievil844
Has anyone installed a Victor EFI intake on a 1994-1995 with a 302 without changing to a fox TB and inlet setup?
Spd0lit
SoCal
you need a adapter elbow from trickflow,edlelbrock,or holley take your pick. All of them are around 100$
stang94X
all you need is that intake, the 90 degree elbow peice that bolts down to where the carb would go and the TB adapter for 94/95 cars
you can also do this with any single plain highrise intake, but you would need to buy the intake that has the fuel injector mounts on it or also mainly known as the nitrous bosses, if the intake doesnt have those then you'll have to buy a set of fuel injector mounts (bungs) to weld onto the intake
Magic
Some time zone
what you might have to modify (if you need/want it) is to modify for a PCV valve system and a coolant crossover at the back of the heads.......
other than that, the Victor EFI is a stout piece........
A
amievil844
Far from stock...8.5 to 1 347 with Stage 2 TFS heads and a vortech strim. nothing left stock but the accessories.
