EGR Vacuum regulator ?
dafizuck
This is kind of a two part question.
First question: Can I relocate the EVR in the fender and extend the plug and use some silicone vacuum hose to connect the vacuum lines?
The next part of the question is I have deleted the egr valve as well as the tube. There is an egr valve position sensor that plugs into it, can it be removed?
Thanks.
duff daddy
I would have to look to see what the standards are on that regulatore, the extended legnth of the hose may or may not cause a change in its reading. But with it deleted (im doing that now so this is a head of a my research) Im not sure why you would still need that.
and question 2, yea id say you could lose that as well.
dafizuck
Some vacuum parts are plugged into that first regulator... that can be deleted if I dont have the egr?
duff daddy
Ill have to do some research when i delete my egr this year... I may just make a phone call for ya over the next few days... ill let you know
dafizuck
^^ sounds great man.. Im on my last leg with this car, losing interest so I need to get this f-er going. haha.
stanger
What advantage does deleting the EGR provide? Just wondering cause I haven't done mine but if it helps then I'm in. Thanks.
dafizuck
Well I have a bullitt intake manifold and its a pain in the ass to mount all the crap that goes with it, thats my reason for dropping it.
stanger
Gotcha, thanks. Don't have one of those yet but it's hopefully in the works. Thanks again.
1996mustangGT
sorry to raise a dead thread, but since i dont feel like putting on all my EGR crap again:
-i took out the metal line from the header and actual EGR thingy that attatches to the Plenum. what else can i delete?
duff daddy
See this is a good reason to dig up an old thread!!! Good job!!!! :thumbsup:
You can delete it in your tune, then just plug off/remove the associated vaccume lines and electrical stuff.
1996mustangGT
To re-re-bring up a dead thread.
What was the verdict from the very top. What can be removed? Can the second sensor be removed?
Lee12609
yes the second sensor posted is the DPFE, its an EGR pressure sensor, no need for it once the ECU no longer looks at the EGR's operation. (turned off in tune)
just dont confuse EVAP parts with EGR parts. you have the EGR VALVE, EGR solenoid, and DPFE. everything else must stay unless you delete EVAP and get the associated codes turned off in the tune aswell.
