elecric fan
dirtyred11
Jacksonville FL
Is there any possible way I can wire my fan up so it will be on high more, or cuts on with the car without it burning up fooses or switches. I ran a couple hot wires and put a switch on it and it got so hot it broke on the inside. Is there any way to change this? ANY COMMENTS OR HELP WOULD BE GREATLY APPRECIATED.....
what size wire and switch/fuse is it burning up? Why are you wanting it to run on high? If everything is working correctly it should not be needed and will only cause a power drain as well as probably cause your alt to run hot as well.
dirtyred11
dirtyred11
Jacksonville FL
I was wanting to find a way to run it because when i got the car it wasn't wired like it was from the factory so i don't really know the correct way to run it, so i'm trying to find the correct way to cool it. The wire i used wasn't to thick and the switch was 50 amps i think. It burned it up in a couple 30 min drives
