electrial problems
chris91
Cincinnati, OH
Thats the width whats the next number on both sets? If you have like a 255/50 on the rear and 245/40 on the front then there is your problem. The speed sensors talk to each other from front to back and if you have a decently different HEIGHT tire that will cause problems.
chris91
Cincinnati, OH
Id bet thats it. The fronts have a sidewall of 4.3" and the rear have a 5" sidewall. Thats a good difference and will throw the ABS off.
because of bad music, no doubt....
But seriously in that vid it looks like the pump isn't working until the motor is under load. Not sure it is a bad gauge, or a bad pump, or what..
sn95 bullitt
sn95 bullitt
Elk Grove, California
Ya. That CD is stuck In there. Do you think it could be a bad sender? The car sounded fine. It doesn't do it all the time. This is only the second time I have seen it do it. @ [MENTION=11896]ttocs[/MENTION]
Could be the sender, could be the pump. Me personally I would not be able to stand it with out putting a real gauge on there to make sure your keeping oil press.
cobraracer46
BFE
First, I would recommend ripping out the aftermarket alarm only because aftermaket alarms in my opinion are a waste of money because if some one really wants to steal a car, an alarm will not stop them. Furthermore, stereo shops employ butchers and I'm guessing that some hack installed the alarm F'ed up the wiring. Secondly, I would buy a wiring diagram book so the condition of the circuits can be verified.
96GTPlanB
Staff online
