Electric seat help!
krazyrabbit
Richmond, VA
I removed my front seats from my '96 GT, the driver seat was connected by the wire set - see first pic. The seats I bought are from a '01 GT, see second pic. Is it possible to connect this seat!? Right now the replacement driver's seat is all the way up to the front of the track so I can't even get in the car if I put the seat in.
If the pigtails are the same then yes it should work. I can't see it on the second picture so I can't tell you forsure though.
Also, even without power there is a way to slide the seat back.
[video=youtube;jH9NRnO7kRA]http://www.youtube.com/watch?v=jH9NRnO7kRA[/video]
krazyrabbit
krazyrabbit
Richmond, VA
Well, the pigtails were totally different, and the track on the chair I'm putting in is also very different. I can see no way to loosen or move it. I might put the passenger seat in the drivers area to take it to the shop to have them look at it.
DeepList
Administrator
Auburn, IN
What's the difference in the connectors? I'm guessing the 01 seats have a 4 pin connector on the bottom of them, and I see in your first picture that your power cord pigtail is just two pin?
krazyrabbit
krazyrabbit
Richmond, VA
Yes, that's right, the 01 seats are 4 pin. Trying Auto Zone to see if they sell an adapter or converter.
Above118
the power seats are so damn faulty,i hate em. i went to the junk yard and pulled a manual seat track and swapped it..best part,only cost 10$...you just lose the up and down function.
DeepList
Administrator
Auburn, IN
You can get them at radio shack, and they come with the pins that you squeeze the stripped wire in and then snap into the connector. That way you can make your own harness to connect the two without cutting anything or splicing your stock wiring.
You will only need to use 3 of the wires/pins in the newer seats. (One wire is for the seat belt indicator light in the dash. The 99+ models have the seat belt latch attached directly to the seat, so that wire can be ignored completely.) With the ground wire of the 4 pin connector facing top left, you need power to the lower 2 pins/wires. The one facing top right is for the seat belt indicator and therefore not used.
I hope that makes sense.
krazyrabbit
krazyrabbit
Richmond, VA
OK, the track from the old seat track from the '96 doesn't fit the '01 seat with the power track. Too bad. DeepList, if you could find the Radio Shack web page with the adapter so I make sure I get the right one I'd appreciate it! If not I'll try taking it up and ask.
DeepList
Administrator
Auburn, IN
I've been looking... I can't find the part numbers. It may be better just to take it up there and have them look. They have those roll-out drawers in the store that has all of the electrical components in them. There's a drawer that has all the molex connectors. It should be there, unless you have one of those "abbreviated" stores where they have to have everything ordered because their stock on hand is limited.
jdude138
