Electric waterpump
blacknotch302
:dontknow: Hey guys im looking in to buying an electric waterpump but the only thing is i dont know exactly what i need... ive looked on summitracing and they have some but the only thing that i am really confused about is the backing plate for the waterpump .. i know that the water pumps from 1987-1993 are different then the sn95 i just would like some help on my situation thx...
blkpitbull
im interested in this also, I will be watching for helpful replies, unlike mine!!!!
94 DropTop
We get to buy the expensive ones home your sitting down or have lube with ya when you see the price.
duff daddy
THey are rated for a limited amount of "hours" or run time on that pump, each one is different, I race my car alot and im running a conventional w/p, I ll have 3 pullies Alt, Crank, W/P
El_Diablo
unless your building a drag machine, theres no reason to go to an electric WP
NERD
Virginia
The quality has went up greatly in the last several years on the Electric WP's. There is no reason a person can't run one on a daily driven street car. I had one on my nova and it made almost 30k miles in Death Valley and even with several cross country trips. The hour rating on some high quality WP's is longer than the warranty most manual WP and even out last a lot of your standard Autzone/Pep Boys reman parts.
I'm not trying to say that they are 100% better or anything but the idea that you can't run EWP at all is silly. Heck even Ferrari and Porsche have factory EWP's on some of their engines.
And the reason to run a EWP is just as much about consistency with coolant distribution than it is with freeing up the few ponies on the top end by helping to reduce rotational drag.
El_Diablo
an oil change in a Ferrari also costs $1500.....
they're more stable but not practical for a daily driven car, if they fail your getting towed home, with a mechanical they usually have a fail period of atleast a week
theres really no reason at all to switch to one unless you just want to waste money, and if thats the case you can help buy my new k member and actually make a difference in a car....... hell, you could do a good bit to your own suspension and feel a difference rather than essentially wasting it, mechanical pumps work fine.... do something that will make a difference
B
blacknotch302
well reason i want one is because it is less drag on ur engine... i know that it wont help a lot but i mean just as long as it helps ill be happy... also yall are right on the price there expensive... i noticed summit had some waterpumps for $130 or something like that... I went to 50resto.com and they had 0ne for $120 plus shipping but there is none available at that time.
LAFENATU
What are you trying to get absolutely every last little bit of power for your street car?
modo
Philadelphia, PA
a quality electric water pump that retains heat and contains the dummy pulley for the serpentine belt is going to cost you around 500 bucks.
waste of time / money for minimal gain
the only advantage it has over stock is the ability to run it with the engine off, thats about it
El_Diablo
minimum you'll spend 300 for a good one and it wont help, trust me, the only thing my old shop had ever ran them on were hot lap drag cars
B
blacknotch302
thx guys for the info i guess ill just spend my money on something else.... i need to get some pics of my car for sure so yall can see it.... once again thx for the info
B
blacknotch302
well im about to drop a 306 in my car that has dished pistons and trickflow H/C/I..and pushrods...i believe 1.6 scorpion roller rockers..bbk 70mm throttle body ... bbk underdrive pulleys..mac cold air intake i realized on the last post i put bbk cold air intake..msd ignition coil...msd spark plug wires...24# injectors and vortech mass air flow calibrated to the injectors..jba headers it also has an aftermarket harmonic balancer.. now im just waiting on my rear end gears 3.73 what brand do you think i shoul get?
Paul
I have a Meziere pump on the 306 I built for the notch, but only because I think it's neato and because I got it for $300.
There's no reason you can't run one on a car you drive frequently. Several friends of mine have run them with no problems. My friend Nic runs one on his 800 rwhp 9 second turbo camaro on the street all the time.
As stated, the power-per-dollar is pretty high. They're cool, but I wouldn't shell out $500 for one.
Paul.
