Engine build ???
RonBurgandy
Pikeville, Nc
So what is everyone torquing their gt40p heads at? And does anyone an easier way to change the cam. I've done 4cyl ohc engines but is there a walk through I can find to do an hci?
Brought to you by Pornhub
I would assume torque for the P heads would be the same as the stock heads because they're both cast iron (haynes manual has the head torque)
As far as changing the cam, You MIGHT be able to get it out with the engine still in the car if you remove the rad. and pull it out through the grill opening. I SAID MIGHT!
It would be better and safer to pull the engine and do it on the stand.
7.5spool
Tn
+1 same torque value
like he said about the cam swap..it could be done in-car but alot less likely chance of something going wrong than if you took it out
