Engine coolant Change
Ralphis
Folks,
I looked around in books and stuff . . but was just wondering to make dead sure .... the flushing of the engine coolant I would imagine is done at the lower right of the radiator (drain plug ) ??
Also, I see I need about 14 qts of Engine Coolant .. what brand do you guys use ?
I was also planning on changing the thermostat ? what do you guys suggest ?
as usual - thanks again :notworthy:
Ralph
GDTrumbo
Nashville, TN
What you trying to do is really just a drain & fill. A "flush" is normally done with a machine.
A 50/50 mix of Prestone and distilled water is what I'd recommend. The premixed version is a rip off.
If the current thermostat is functioning well I would just leave it alone.
When refilling, remove the temp sensor from the intake's crossover, fill block up, reinstall sensor and proceed to fill the radiator & burp tank.
Run engine till at operating temp, turn off and let sit for a couple hours. Later, check level, fill if necessary and drive it a while. Keep an eye on the level for a few days. Should be good to go.....
GT
R
Ralphis
the temp (engine) seems like it does not go up as it should .. has a hard time coming off the "c" mark .... so I'm figuring it's lazy a little ... :)
joekd
Ct
If it takes a long time to heat up your thermostat may be stuck open, worth spending the money on a new thermostat and of course gasket
GDTrumbo
Nashville, TN
Oh. Didn't know about the temp situation. You could fill the block quite nicely just before the stat/seal install.
You may not feel comfortable with this but, a popular practice is to take the new thermostat and drill a 1/8" dia. hole outboard as possible in the center plate to help with air pockets in the block during the fill process. Just throwing that out there.
GT
joekd
Ct
I also drilled mine before I installed it (did the boiling water test first to make sure the thermo worked fine) figured it can only help
Also added one bottle of Redline water wetter
97GT4.6
Colorado
I say get a 180 stat for it while your at it. Flush it out with water.. you can pull heater hoses to flush them out as well if you wish..
96GTPlanB
