Engine stalling when come to a stop. FIXED!!!!
94califiveoh
I'd figure I'd write my success story on how I fixed my stalling problem. I posted on several forums and did tons of research did tons of work and was about to sell my baby because I could not find the stalling problem. Well, call me stupid (seriously) but the bleed screw on the throttle body fixed my problem. I had it partially closed and figured I would start out by having it as open as possible and work from there. Sure enough, the motor loves when the bleed screw is wide open. OMG Im so pumped today.
modo
Philadelphia, PA
its not a band aid. the idle set screw is the idle set screw. the iac just works around whatever the base is. if the tb was completely closed the iac is not fast enough to counter-act a complete starvation of air
you will want to monitor the tps reading though
modo
Philadelphia, PA
wait i just read that the screw is fully open... (read it too fast). the screw should not be fully open
