Engine tick?
RideThePONYgt
hey guys theres ALWAYS a ticking noise on the passenger side on the car. cant hear it inside ut if your standing outside towards that side you can hear it. speeds up with the gas. any ideas? ill see if i can get the noise in a video can i post that in here?
2slo95fiveoh
Lawrence, Kansas
X2. Check Exh manifold gasket, and EGR tube mating surfaces... Also, If you think it's in the valve cover, do you have factory or aftermarket heads?
R
RideThePONYgt
everythings stock right now im trying to save and do everything at once. the noise is always there tho weather im just starting it or have been driving for an hour. cold or hot its there. it does sound like its in the valve cover or right around there but ill go through all the things you guys mentioned as soon as its done raining.
sn95gtvert
Spokane Washington
i had this problem the other day. had the noise for 8 months or so. i finaly got tired of it and checked my passenger side header. replaced the gasket and its gone.
the sound did seem like it was in the valve cover but it was no such thing.
96GTPlanB
