erratic miss
mattm
my 95 gt picks up a random miss that can be fixed by cycling the key off n back on while driving somrtimes it will take care of it for hours others only a minute or two it has the pro m pih computer conversion i am running the older style fox body ecm the a9l ecm the car has a b303 cam gt 40 iron heads a 95 cobra intake 24 lb injecters pro m air flo meter with the correct sample tube pro m power pipe n a 70 mm pro products throttle body tps is in range fuel pressure is 38 psi
mattm
ended up figurin it out myself ended up bein 02 sensors had no idea that would do that bein as a friend of mine never seems to be runnin any n his car seems to run fine other then runnin a little on the rich side
