Gas smell and probably a beaten to death topic.
weendoggy
I made the mistake of using the old school extruded rubber lines first time I did an AN fuel system. It was fine for a while (Earls brand too and not some off-brand Amazon junk). Took about 6 to 9 months and I started smelling it if it was parked in the garage for a few days. I imagine over time it would get worse. PTFE is the only 100% guarantee you'll never get fuel permeation through the lines.
I used Earls XRP for 15yrs on my Cobra without incidents. I changed to PTFE during my frame off. I use Fragola on my Coyote. I never had a gas leak or smell with the XRP. No exotic fuel as well. I do agree that PTFE lined is the way to go.
cobrajeff96
Germany
And I think someone already mentioned it, but you gotta be real careful about accidentally mixing/matching one brand's fittings with another's hoses. That's another reason I stick to one brand whenever possible. I've come to know Earls and XRP quite well over the years. It's not sobbery when I say I only buy their products (mainly Earls).
Snorky
Snorky
has a clip on the bottom
I suppose it's this one? 5/16" to 6an?
And I can't seem to find that other style for thr other line. Seems like all I can locate so far is this
RAU03MACH
NEW MEXICO
i have 2 of them 1 of them is the small fuel feed
the other is a little larger for fuel return but i need to check that size
RAU03MACH
NEW MEXICO
ya you can hook into those
but im changing fuel rails also on mine only to get away from the cross over hose at the front or rear of original fuel rail
RAU03MACH
NEW MEXICO
I can't remember for sure
On my 95
I unhooked the lines and had fuel psi comming out of the smaller line that has been a while back
I'll have to check it again when I redo everything in the engine bay
94IndyPace
If you are referring to the rubber sliding. That is just the protective hose. The actual line is a harder plastic underneath on the barb.
Also the Tuning Innovations lines are top notch, I have them under the hood and at the tank IMG_4999.jpeg
Snorky
Snorky
Also the Tuning Innovations lines are top notch, I have them under the hood and at the tank View attachment 42213
Wpw you cleared a lot of things up for me. Thanks everyone!!
