Excessive Oil Consumption ???
delling3
Sterling Heights, MI
This may have been covered before, but a search didn't reveal anything.
1996 GT. Basically bone stock motor with 95XXX miles. Been sitting mostly since the around 2009.
I acquired the car a few months ago. One of the first things I did was change the oil with 5W30 - simply based on the age of the oil in the car, and not on mileage. Since then I have put around 1500 miles on the odometer. Car starts, and runs, no issues, has good oil pressure. No excessive smoke or smell of burning oil in the exhaust. No leaks showing up in the driveway. I started the car this afternoon, and the low oil light was on.
Not sure how low the oil is, as it isn't showing on the dipstick. I am guessing could be two quarts low.
So, do these motors use oil as a rule? I had a Cadillac with a Northstar V-8 that used a quart every 750 miles. It was a very low mileage motor. Was told that the piston rings tended to get stuck due to carbon buildup, and the result was a lot of blow-by. Are the 4.6L's the same way? I will make it a point to monitor my oil level more regularly, but curious if I have a problem, or if this is simply a characteristic of the breed? Should I stick with 5W30?
delling3
delling3
Yeah, thought about a head gasket. Looking at the coolant in the reservoir, it looks pretty good - not foamy or chocolate milk looking, and the coolant level is normal. I know that doesn't rule this out, but would like to eliminate the other stuff first . . .
delling3
delling3
Well, it seems that the oil pan on this car must be pretty shallow? I just added a quart of oil and the oil level went from not registering on the dipstick to reading in 1/2 way between the L and H marks! For a six-quart oil capacity, I would have expected that the low mark represented a quart low. So, one quart in about 1500 miles . . .
g36 monkey
Orlando, Fl
That seems like it's using more than normal, however you don't know the condition of the motor. If it sat for 9 years I imagine the seals are doing all that they can just to hold together
96blak54
Staff member
Lawrenceburg Kentucky
Assuming no power adder had ever been used, its probably the valve seals. Early 96 didnt get the update valve seals. The pre96 seals didnt hold up well for very long.
Also these engines have 2 cams that spin oil into atomization and gets suspended in the air which in turn gets sucked into the pcv ultimately into the combustion chamber. The answer is a catch can. You can pull the intake tube from the throttle body and check the throttle blades back side. Probably wet from oil.
Exeter Ontario
This is just a stab but based on something I had happen with an old flathead V8. It had sat for many years and some of the rings had stuck as well as a valve. I used Risilone in it and ran it for for several short trips, always letting the engine warm up, it just ran better and better, then I changed the oil and the old engine was fine, no excess smoking or missing. Several folks think seals and that is a real possibility
Silver95bird
Our 95 4.6 tbird used a quart of oil from day 1, every 800 miles or so. My 97 did too, until I changed the valve stem seals. It's completely normal in a pre-98 4.6.
