Exhaust Leak
Brian95SVT
Chesapeake, VA
Anyway to find out if I do have an exhaust leak?
If I start my car for the first time and let it sit for a few seconds then rev it, it starts to like freak out and bog and if i get underneath my car it sounds like an exhaust leak but then after a few seconds of freakin out it goes away then runs fine...
If I start the car and let it warm up it doesn't do it at all.....
STEEDA96
since warming the engine up seems to stop it, i think it may be a manifold gasket. heat expands the seal, providing a better seal, but as it cools, the leak re-opens. Plus since the leak has such a dramatic affect on throttle i would expect it to be close to the engine. Never had this problem..just an assumption.
also..check eng light?
reivaxtorres
pretty much what i was going to say.
and its somewhat easy to smell if you have an exhaust leak. can you smell any fumes under your car, or under your hood when you open it?
B
Brian95SVT
Chesapeake, VA
No CEL, No fumes. Sometimes I get a little wiff of something but it's not like common.
reivaxtorres
STEEDA96 said:
im not one for just throwing parts at anything, but gaskets are like 10 bucks at LMR. cant hurt anything. otherwise id go over the whole exhaust system with a fine tooth comb. not literally
the comb would melt....lol :hammer:
the gaskets may only be $10 each, but if we are talking the exhaust manifold gaskets (that go between the head and the manifolds), you need 4 of them, and its a PITA to change them.
check to make sure you dont have any openings on the intake side of the engine, like a loose intake tube, loose intake pipe, anything. just like heat affects the expansion of the metals for the manifolds, it has a funny way of doing the same to rubber.
Bluesn95
Waco
Honestly doesnt sound like an exaust leak. My car used to be the exhaust leak king and I've never had anything close to what you described. I've had bad exhaust leaks in every place immaginable and never caused my engine to run rough. Sound like you have trash or air in fuel system. Maybe somekind of injector problem. Could also be a warped intake manifold that seals up once the engine warms up. Are you throwing any kink of engine codes?
B
Brian95SVT
Chesapeake, VA
already said no CEL
scarface
Guest
get a pair of gloves, start your car, cover both exhaust tip with your hands... If its leaking, you will hear it escaping from somewhere else.
Bluesn95
Waco
Exhaust leaks don't cause the car to bog. I think your intake manifold is leaking. That manifold isn't designed to match up with that set of heads from what I understand although lots of people do it anyways.
B
Brian95SVT
Chesapeake, VA
I never said my car bogs... well i did i said when i FIRST started it COLD and just straight REVed it up it would start to like spudder ore of a "bog" and it looked like there was water drippin from underneath where one of the clamps are.
I think my intake is leakin antifreeze but its not a lot at all.. just a little.
Bluesn95
Waco
That intake may be the problem. Did you put it on? Did you have to use a lot of rtv?
B
Brian95SVT
Chesapeake, VA
The shop that put my motor did but they aren't a "tuner shop" or anything, just a regular shop and I don't know if they did put it on there or not and I haven't had a chance to find out myself... kinda scared to do it...
Bluesn95
Waco
I may be totally wrong but from what I understand is that without the pi heads the ports on the intake don't match up excatly and usually a lot of rtv silicone needs to be used. The problem with usuing a lot of this stuff is that eventually over time the rtv may actually be slightly sucked into one of the ports causing a sealing problem. When the engine warms everything up it may then make a better seal causing it to seem like the problem has gone away. Have a compression check done on your manifold. Cost is about 40 bucks but it will help u find or eliminate one of the possible problems. This is just my take on things.
B
Brian95SVT
Chesapeake, VA
hrm as far as i was aware you just use PI gaskets and it fixes the problem or ive even heard of an adapter but yeah
i will have look into that
just bring it to a local shop and ask for an intake compression test?
Bluesn95
Waco
Yep any place that does moderate car repairs and isn't a hole in the wall should be able to do it. When my intake finally warped (thats a common problem with original npi intakes) I just took it to ford and they did it in about an hour and just like I thought my intake was leaking coolant because it had warped.
Bluesn95
Waco
If the people that installed the pi intake didn't know that the intake you gave them wasn't original equipment on your car or didn't know the correct procedure for installing this particular intake they may have not used any high temp gasket maker at all causing your current problem. That just came to me.
