explain hood pins to me?
immenukka
hey i am kinda of new here.. i have been lurking mostly but anywho i just bought a 95 cobra r hood and it was drilled for hood pins.. although i really do not like hood pins i heard it was best to use them.. the only reason i ask is because i have seen the hood pins go from the top of the hood to somewhere inside the headlights.. and after that i really dont know what happens under the hood... so how do they work? how are you suppose to install and use them? pics would be nice.. sorry if it seems like a dumb question but i am confused
Downshift
94 DropTop said:
just use a latch
His hood is already drilled for pins.... Might as well get pins.
I personally like them. Basically there is a stud? not sure what you wanna call it but that sticks up from under the hood and when your hood is closed they come up through the hole drilled in the hood and a pin is stuck through a hole in the studs to keep the hood from coming past the pin.
Can you get away with just the latch, thats debatable. I would just use common sense here, theres a lot of force going 65+ pushing up on the hood. Friend of mines Cervini hood would kinda wobble up and down a bit on the freeway cause the latch was not holding on too good so he got pins to be on the safe side.
94 DropTop
i would have them filled and just use the latch. You better make sure you put them in every time. Trust me its easier to forget than you think. I have a abc hood(s) and i have never had a problem i cruise at 75 on the highway daily here.
I
immenukka
yea i am thinking my hood is from there too.. but i am not really all that sure..
[/quote]
[/quote] thanks man.. i might put it on and show you how it looks in a day or 2. it looks like he was using the latch already but was using hood pins for back up i guess.
I
immenukka
dunno.. i want to say fiberglass but i could be wrong.. i'll check tomorrow
I
immenukka
is there anyway i can convert it to steal so i wouldnt have to run hood pins?
i'm sure you could but it probably wouldnt be worth it, the latch receiver is pretty much part of the hood. Get the right hood pins and it'll look good dude.
I
immenukka
well it does have the metal.. a little beat up but it looks good still.. and what hood pins do you think looks good?
I
immenukka
pics of if..
well if it's got the steel latch you should be fine without hood pins as long as it's installed and aligned properly. If you still need to get the hood painted just have them fill in the holes, if it's ready to go on the car just buy some cheap hood pins to fill the holes, something like this should work just fine.
I
immenukka
well i am getting it repainted along with the rest of my car.. so i was thinking of getting it filled.. where would you recommend getting some reliable hood pins
I
immenukka
OnyxCobra said:
I thought you didn't want hood pins?
eh im iffy about it.. i do but i dont, i just want to see my options before i go through with anything
94 DropTop
if you do use pins you better have a latch as back up. Like i said its easier to forget than you think. ive had a hood come back into the glass at 60 and its not fun
i remember that, wasn't it the Saleen hood? That would have to scare the shit out of you.
94 DropTop
Well first it was a saleen hood, i was a dumbass and forgot to put them in after working on it. The second time is was a y2k cobra r, someone stole the pins out of it at like 3am at walmart :wall:
