few issues with the cobra
TxCobrA98
besides the big one involving my motor be rebuilt, i got a few issues with the cobra.
ok, so one problem i am having is when i go to start my car. When i turn the key (thats how you start my car... i know its rare) the engine will turn over, but it seems like only 2 or so cylinders are firing. so i either give it a bit of gas and then the engine will fire up fully, or i just turn it off and try again. sometimes when i turn it off and try again i get the same result or it will turn over fully.
another problem, well idk if its a problem, but when my car is idling and/or after i give it a little gas (while sitting still) my exhaust seems to be "ticking" right under the driver seat area. it will go up the rpms for a bit but i can't hear it after like 3k rpm due to the exhaust being to loud. it just makes these fast little ticking noises. its not a knock or anything (ive went up to the engine bay and listened and can't hear any knocking).. its just a ticking noise.
ummm what other problems. oh back to the engine not firing, sometimes it will not even fire up. it will ALMOST crank then die.. so just like scenario 1, but it wont fire up fully (starts combustion cycle it seems but dies after the first one)and then it will just die.. and yes im turning the key long enough. :santa_grin:
SRT Handz
our cars just have weird little ticks. my make noises sometimes and others is sounds like it running perfect...ust depends on the day of the week
Fets
Usually a lifter will stick on startup. Mine does and I read its common.lol My exhaust ticks after I turn the car off.
Passenger
As for ticking under the driver seats, check everywhre your exhaust connects, make have a leak.
T
TxCobrA98
ive never known what a exhaust leak sounded like.. what should i listen for specifically?
