I figured I put all my questions in one thread so here they are.
First, is there any difference in the instrument cluster in an auto verses manual. I noticed that my car has a light that says OD off which is overdrive off obviously. Did ford put all the same clusters in the 94-95 and then just not use that light in the manual or was it a different cluster?
Also is there any difference in the shifter bezel in an auto verse manual car?
and my last question is would an auto computer cause a car with a manual trans swap to hang for like 2 secs when you shift or is that most likely the IAC valve.
Thanks for your help.
Also on the first question I need you to be really specific. If ford did use the same clusters on the manual and auto, was the bulb for the OD off missing or is there no OD off symbol all together. Im trying to make the trans swap completely undetected.
