Fog Lights
98SlowStang
Hey guys i am putting in some fog lights in my 98 v6 and i just had some questions on wiring. I have the fog light housings itself in and now i am just trying to run the wires and get them working. I got all of the parts myself out of a mustang so i took all the connectors as well thinking that they would help me when i go to wire them in. So in here lies my question, im trying to make it all as stock as possible so i am using the connectors on the back of the fog lights the switch that goes in the center console with the plug that connects into it. My question is number one what are the different wires that come from the connector for the switch. My second question is how i should go about wiring all of this, i know i take the black wires coming out out of the back of the fogs and ground those, and take the red wires and connect them and then run it into the switch i just dont know which wire on the switch to connect into for the lights, or the wire that i should run to the battery that has the inline fuse.
*** Just realized that i probably put this in the wrong section. If it is mods please move it ***
Grim94GT
Hopefully you got your wiring figured out. But if not, heres what I would do. Ground the negative wires on the lights to a good ground. Then run your positive wire into the center console. Im not sure how many outputs are on your fog light switch, but tap into the convertible top switch (into orange n purple wire) get power from that and then just hook it up to the switch... and this might help too http://www.mustangworld.com/ourpics/fcar/fog1.htm
