Ford 9" swap
94_CobRa
Hey guys, new to the forum.
I got a 94 cobra that im building up. Im going to put a 9" in it.
Anyone on here done this yet or know who has?
Thanks
Paul
I've not done it, but there are several companies that off bolt-in 9" axles for your car. Keep in mind though that the 8.8" axle can be built to withstand a ton of power, it's lighter, and the build will likely be less expensive.
94_CobRa
Thanks for the info.
I looked into building up my 8.8 and the cost difference was almost none.
Yea, its heavier and its a little overkill but i will probably never have to fix it. I like the idea of a 45min. gear change too.
Paul
What 9" axle are you planning on buying? And from where?
94_CobRa
for the 9", they are 31 spline moser axles.
yes, 500 for those parts. not including the cost for c-clip eliminators, gears, & install kit. then add $450 in california labor.
Comes out to about the same.
wayne94mustang
my old bronco has a 9'' rear and they do have a weak point that took me awhile to solve.
I'm on my 5th rear in 7 years, kept busting the main caps off.... long story short is i had big time axle tube flex.
once the center section is out the rest of the rear cant weigh more the 40lbs, real cheesy thin sheet metal. anyway, a weld on axle truss saved the day but if you make tons of torque and can get it to the ground you can/will break a 9''....often.
another thing to remember is the 9'' has a super low pinion gear so your drive shaft will be lower as well.
94_CobRa
I will not be breaking my nodular iron 9".
If i do its under warrenty.
Steven
SC
Doesn't make much sense. Unless your consistently at the track, and chasing E.T.'s a 9" is really overkill. If price wise it comes out even, weight wise it does not as you obviously said. Your welcome to do what you want, I just find it a bit useless anymore outside of a track car use.
wayne94mustang
so now your getting a N case as well?
im calling BS, there is no way that 9'' cost the same as beefing up your 8.8.
