Ford racing harmonic balancer question?
Hey guys.
I just purchased the ford racing SFI balancer. I was wondering if any of your guys have used this balancer and know what to modify. I already have the spacer(B531 for H.O)
M-6316-A50** 302 (1981-93) 50 oz.-in. 1 Meets SFI 18-1 5 12.1 6
1 Damper has removable weight that allows use as a neutral balance unit for internally balanced crankshafts. 1994-01 Mustang and Explorer requires modification.
Where do i need to modify to use this on our 94-95 cars?
Let me know and any help would be great!
Thanks
tommybunz
i just brought a new sfi balancer w/ spacer to and wondering if i need to modify also dont think so i think the spacer is the only mod
Win
Kennesaw, Ga
If you bought that specifically for the 94-95 it should come with any spacer necessary. Where did you pick it up.
H
I bought mine from summit and i purchased the spacer also from summit. they are both ford racing. some say i will have to grind on water pump or something.....
Any help would be great :)
Thanks
birel21y
yes.. its a pain, but possible. You need to use the right spacers, (1/2 inch i think) and you will grind the very bottom of the timing cover almost all the way to the bolt itself for clearance.
H
It's a 95 302. So I will have to grind the bottom of the timing cover to the bolt? Is that an easy task? or something i will get frustrated over? I believe i got correct spacer...the b351 spacer. 80-up later 5.0's
If you have done it do you have picture or some sort? or can you give me an idea of where?
Thanks
tommybunz
my balancer says its a 6.4 so i dont think i should have to grind well hopefully. and the spacer should be 3/8" not 1/2".
birel21y
No pic, sorry, but you will see when you try to put it on. Its the very bottom of the timing cover. :eek:ccasion14:
wayne94mustang
i had to clearence the water pump on mine or maybe it was a bolt....its bin over 6 years ago but i dont remember grinding the bottom of the timing cover at all.
the problem was the top of the balencer was hitting somthing.
