Fox Valve Covers on 95 GTS with Vortech
MORDENENOUGH
I'm just starting my supercharger build and had a couple of questions...Does anyone know if Fox Cast Valve Covers will fit with a Vortech on a 95 GTS? Does the fill tube hit the intake pipe from the supercharger? Also has anyone run a oil separator for the PCV system in this set up and if so could you recommend a brand?
Thanks Steve
MikeF
they will work if you modify the baffel and oil fill spout.I used the tfs short valve covers because it was with the tfs top-end kit but there only like 100 bucks
mikey94gt
I used the Moroso oil seperator can, and plumbed it up to the PVC system. It works much better than the stupid Craftsman oil separator that alot of guys use, but it costs alot more.
FOX valvecovers will work for sure, just gotta mod them like MikeF said.
